Are K & N air filters really better than OEM ?
found this on their site:
How often do I need to clean my K&N air filter?
If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible.
And on cleaning:
1. APPLY CLEANER
Liberally spray K&N Air Filter Cleaner onto both sides of filter and allow to soak for 10 minutes to loosen the dirt. Do not allow cleaner to dry on air filter.
2. RINSE FILTER
Rinse off air filter with cool low-pressure water applied to the clean side out in order to flush the dirt out of the filter. Continue to rinse the filter until all traces of cleaner are gone. It may be necessary to repeat steps 1 and 2.
3. DRY FILTER
After rinsing, gently shake off excess water and only allow filter to dry naturally. Do not oil until the filter is completely dry.
4. OIL FILTER
A.) Squeeze Oil (99-5050)
Apply K&N Air Filter Oil evenly along the crown of each pleat. Allow oil to wick for approximately 20 minutes. Touch up any light areas on either side of filter until there is a uniform red color at all areas.
B.) Aerosol Oil (99-5000)
Spray K&N Air Filter Oil evenly along the crown of each pleat holding nozzle about 3" away. Allow oil to wick for approximately 20 minutes. Touch up any light areas on either side of the filter until there is a uniform red color at all areas.
The above process is the only approved procedure for maintaining your K&N Air Filter.
And on cleaning:
1. APPLY CLEANER
2. RINSE FILTER
3. DRY FILTER
4. OIL FILTER
Do not use compressed air on the k&n filter, you'll damage it. Just follow the instructions that come with the cleaning/recharge kit. I run k&n on my cars simply bc they can be reused. I run a BMC (reusable as well) on the 954 as well as many other members here. I found on the forums some dyno results that showed the k&n filter made less HP than a stock filter.
Actually yes they do flow air many time over better then a OEM filter. Little time spent on a Dyno with my Buell and my Subaru have varified that.
I'm sure they do. And I'm guessing that, like everything else they run, isn't the same one we can buy. With all that tuning and mods, it probably makes a difference when your talking fractions of seconds on a track.
But does it make a big enough difference, or any at all, for a stock bike on the street? If it does, its probably minimal at best. It's value is mostly in the reusability, rather than power gains. Would the average everyday rider notice the improvement? I'd like to see a dyno test, not run by k&n, that reports actual real world gains on Honda bikes with only an air filter change.
As for our cars, which are designed for economy and gets filtered through regulations up the ying yang, the gains are enough to justify the cost. But that wasn't the question....
