issue spotted !!!! check it outttt
Old Apr 24, 2011 | 11:09 PM
moses25's Avatar
Default issue spotted !!!! check it outttt
[IMG]http://i1180.photobucket.com/albums/x412/inked25/mName:  exhaust2.jpg
Size:  19.2 KBy%202003%20cbr%20954rr/exhaust2.jpg[/IMG]
Old Apr 24, 2011 | 11:12 PM
moses25's Avatar
so i pulled off my stock exhaust too prepare my new one too go right on when it arrives and i spotted this hack job it appears the previous owner cut this pipe what would this normally even look like having he never cut it ?? im thinking he cut it too make the stock pipe louder ??? fedback please
Old Apr 25, 2011 | 03:06 AM
moosestang's Avatar
I'm guessing he cut off the baffle, but I don't know what the inside of a stock pipe is supposed to look like. Maybe the bike had a slip on installed at one time.
Old Apr 25, 2011 | 08:07 AM
txsmainevent's Avatar
Depending on the slip on you use, there is a cone you have to cut off. That is where the cone used to be. I guess if you wanted to reduce weight you can cut it off. It wont hurt anything and im pretty sure it doesnt act as a baffle. You wont hurt anything removing that. I think it boils down to preference and certain pipes.....
Old Apr 25, 2011 | 09:49 AM
letsride's Avatar
He probably had a slip on before.Most slip ons require the removal of the CONE in order for it to fit.Some slip ons require you to cut even more.I had to do that to fit a Two Bros.
Old Apr 25, 2011 | 11:17 AM
moses25's Avatar
ahhh i see yea thats funny cause my new pipe is a two bros should be here today !!! what ever as long as it doesnt hurt nothin for the pipe too be like that
Old Apr 25, 2011 | 11:22 AM
letsride's Avatar
You'll see what needs to be done if anything when you get your new pipe.I had an older model Two bros.
Old Apr 25, 2011 | 02:16 PM
backdoc's Avatar
The cone is a spark arrestor. Some bolt-ons are large enough diameter inside to allow you to keep it where others require you to cut it off. I know with Microns you can keep it and Two-Bros you have to cut if off.
skip954
Apr 10, 2012 10:20 PM
shakey
Sep 5, 2010 12:09 PM
Mo777
The Hurricane Saloon
Aug 5, 2009 09:35 AM
VP
Jun 28, 2008 03:08 PM
Onarom
May 6, 2008 10:16 AM
