ignition
Old Mar 6, 2012 | 05:53 AM
03 SB SVT's Avatar
Registered Users
Default ignition
Well for some reason my other thread got deleted before I had my question answered. Since my bike is missing the key can I purchase an ignition and key off eBay and just plug it in or do these need programmed to the bike like all the new cars are?
Old Mar 6, 2012 | 08:12 AM
backdoc's Avatar
You can switch the ignition and it work fine. Just make sure you get the ignition, gas cap and rear seat lock as a set. You may want to call your local Honda dealer because they may be able to make a key for the bike using the VIN. If not try a local locksmith before buying another ignition.
As for your deleted thread I know how you feel. There are certain moderator's going around deleting anything they want. I know because they deleted my post from your thread before the entire thing was deleted. I have also had other threads deleted in the past few weeks. If it continues I am leaving this site for good.
Old Mar 6, 2012 | 10:13 AM
03 SB SVT's Avatar
Registered Users
Thanks I stopped into the local dealership and if I pull the ignition out they can make me a new key for $30 now to just figure out how to pull it out.
Old Mar 6, 2012 | 03:27 PM
Conrice's Avatar
you have to drill through the bolts on the underside of the triple....
been there, done that...
Old Mar 6, 2012 | 04:24 PM
MadHattr059's Avatar
Don't know on the 954 but the F3 uses a gi-normous torx (x2), to hold the
ignition in place.
+1 on the whole gas-cap, helmet-lock and ignition. Bolt-on replacement is
the way to go.
Either, estate or adrenalin (I think it's, one of the 2), have a write-up on
removing a locked-down gas-cap. Pulling the screws doesn't do it. The cap
itself, locks over the flange on the tank.
After you do all of this, write the number on the key down. Somewhere that,
you'll find it later. I used a 'sharpie' permenant marker and wrote it on the
inside-lid of my toolbox.
Go to a lock-smith NOW (usually, it's a 'no-go' at the hardware store),
get a couple of extra cut. You'll be glad you did, later.
Good luck, Ern
Old Mar 7, 2012 | 08:40 AM
03 SB SVT's Avatar
Registered Users
Alright thanks for the help once I get the mustang back together I am going to tear into the bike
Old Mar 14, 2012 | 11:02 PM
pascalwilli's Avatar
New Member
Hi you should call a local automotive locksmith.They will definitely solve your problem.
Old Mar 15, 2012 | 11:14 AM
moosestang's Avatar
Why drill through the bolts? Are they security bolts?
My buell has securty type bolts holding the ignition on, but a little work with a dremel to a cheap torx bit and voila!
Old Mar 15, 2012 | 06:57 PM
letsride's Avatar
Is the steering locked? If not just remove the triple tree and the ignition should come off with the triple tree.
Old Mar 15, 2012 | 07:55 PM
Conrice's Avatar
yup, security bolts. i don't mind drillin though....
duh.... that's def what should be done in this case. good call. i was selling locksets and moving my ignition - didn't occur to me to think like that
