How make a good drag start
Old Jun 25, 2008 | 11:24 AM
picolino100's Avatar
Default How make a good drag start
Hi everybody
The more important to to make a good time on the 1/4 mile is the start and i want to know
what are yours technique to make it good.
- Atwhat rpm doyou turn motor before release the clutch?
- How you release the clutch?
- e.t.c
Old Jun 25, 2008 | 12:47 PM
Hcstreetriding's Avatar
Default RE: How make a good drag start
11000 rpm and just drop the clutch. lol ive been very conservative on my 954 so far and most i have done is rev about 3-4grand and ease off the clutch and with it down geared it will still pop the front end if get into it a little too much. will be putting back to stock rear sprocket and -1 in the front this weekend or next and see how different it is like that. Might be able to get more controlable starts then.
Old Jun 25, 2008 | 05:22 PM
skarocka's Avatar
hope he dont try that he will be on his ***, mine comes right up on me like 4 practice u will find her sweet spot
Old Jun 25, 2008 | 05:34 PM
Haha, yes lets make clear that dumping the clutch @11000rpm is not a good idea. unless your trying to convince your wife that you need new fairings... and tailbone. Skarocka said it, practice makes perfect.
Old Jun 25, 2008 | 05:56 PM
txsmainevent's Avatar
I dont dump the clutch, seen to many clutches needing to be replaced after their run. I like to get to about 5 g and slip the hell outta the clutch. 1st time on the track ever running the 8th(they closed the 1/4 due to alot of wrecks), i was consistent at around 7.1 give or take a tenth.Also i dont clutchless shift either, for some reason I cant do it im just so use to clutching.
Old Jun 25, 2008 | 11:03 PM
TK954RR's Avatar
Jan 2009 ROTM
I like to be at about 3-4k and i release it farily quick while rolling into the throttle. In my experience i ran better times getting the clutch disengaged as quick as possible and being on the gas. As opposed to slipping the clutch halfway thru first to keep the tire down. However as stated above, lots of practice.
Old Jun 25, 2008 | 11:39 PM
cbrRick954's Avatar
i goose the throttle with the clutch in, then let out the clutch, and tickle the trottle till i'm moving fast and still on 2.
i beat a hyundai sonata with that technique...it was close though
Old Jun 26, 2008 | 01:32 AM
ORIGINAL: cbrRick954
I lost to a chevy cavalier once because i reved a little high and droped the clutch a little quick and then **** my pants at 12 o'clock and rode the rest of the way home under 25 mph, lol Practice, practice, practice, dont go out and think your and expert like i did, it doesnt work.
Old Jun 26, 2008 | 05:48 PM
NastyNINA54's Avatar
practice makes perfect. u need to figure out what rpm is best for YOUR bike to start off. each bike is a little differant. as far as the clutch goes, i slide off the clutch while rolling into the the throttle. popping the clutch out increases the chances of awheelie. its pretty basic once u try a few times. take your time learning andgood luck.
Trent Dog
Jun 12, 2012 12:22 AM
mrcbr25
Mar 15, 2012 03:04 PM
Dipstix6996
Jun 30, 2011 02:10 AM
roys654
Dec 10, 2009 09:41 AM
wood83
Apr 20, 2006 01:14 PM
