How do I remove the direct ignition coils from the spark plugs?
Old Oct 21, 2007 | 04:35 PM
Mikes03954RR's Avatar
Default How do I remove the direct ignition coils from the spark plugs?
Hey guys. I am having a hard time getting my direct ignition coils off from the spark plug. I have removed the coil plugs but am unable to remove the coils from the plugs themselves. I've tried to maneover and the still will not budge. Is there a special tool I need or do you just continue to pull at them until they come off. I need help. I'm sure someone out there has changed their plugs. Please help!!!!!
Old Oct 21, 2007 | 04:55 PM
bobjoezx's Avatar
Default RE: How do I remove the direct ignition coils from the spark plugs?
what are u saying is you can't pull the coil off the spark plug??? just pull
Old Oct 21, 2007 | 05:01 PM
I have the connectors off but cannot get the actual coils that sit on to of the plug off. I have tried pulling them off with no luck. So your saying all that I need to do is continue to pull at them? What happens if I break one of them?
Old Oct 21, 2007 | 08:00 PM
bobjoezx's Avatar
i c, ya just get as far down on the coil you can and pull.. they have most likely never been changed so they are seized on there pretty good but yes just pull.. i dont think you will break one, worse case you have to replace on, then you will have a excuse to replace all 4 which wont hurt but i wouldn't worry about breaking the coil.. just get a good grip and pull
Old Oct 21, 2007 | 08:44 PM
Can I spray some lube on them or is that not a very good idea? Yes you are right the plugs have never been changed. It says you can put 32K on the plugs before you need to change them in the manual. I think that is bull**** and I know I will get better performance with new plugs on. Going to change them every season I think. I will continue to work at it and keep you updated. Thankx bobjoe
Old Oct 21, 2007 | 08:57 PM
bobjoezx's Avatar
ORIGINAL: Mikes03954RR
lube? you mean after u get the coils off, there is anti seize for the coil, but i woudlnt' worry about it, it's a good idea to change plugs every season to every other season.. go with the stock NGK's.. from auto part store about 8-10 bucks a piece, better then the dealership at 17 bucks a piece..
Old Oct 22, 2007 | 08:47 AM
Yah I went to the parts store and the Stock NGK's were still like 14 bucks a piece.
Old Oct 22, 2007 | 06:06 PM
bobjoezx's Avatar
hm advanced auto parts are 9 bucks a piece
Old Oct 22, 2007 | 09:55 PM
TK954RR's Avatar
Jan 2009 ROTM
Dont know if your still stuck or not, but twist them a little (side to side, say from 12 oclock to 2 oclock)to break the seal, then try pulling again.
Old Oct 23, 2007 | 02:23 PM
demonchild's Avatar
spray wd 40 if you can get it into there.
