honda 954
Hello, my problem is that twice the wear of the laboratory test oil drained from engines and the relatively few miles ,l indicates the presence of gasoline, but not very significantly reduces its viscosity,which is worrying some can you tel me something this problem ,and under what circumstances' may appear similar problem
what have you done to the bike? if you're running too rich, gas could be getting passed the rings and into your oil. that or something could be wrong with one of the injectors.
edit - what kind of miles per tank are you getting? how does the bike run?
and are you getting an oil light from the gasoline being thinned out?
hello,checked injectors working properly engine ignites its normal l have no comment on his work when it's cold weather injectors spray more fuel but do not notice anything wrong is not a rich fuel mixture ,made measurements of the sensors , everything is as normal ,can you get me focus on something ,thanks
Jnothem
Oct 18, 2011 02:10 PM
MARTINEZ
Apr 7, 2008 12:23 PM
