help with triple trees needed
Old Jul 11, 2006 | 10:38 PM
fafar59's Avatar
Default help with triple trees needed
I changed my 954 triple trees yesterday,b/c they where damaged from an accident. Everything was going well till today I slammed on my front break and the triple trees moved in its place. Since then every time I break it moves a little bit. I know I need to open every thing and redo whole assembly procedure, but I was wondering if you know what causes such a problem
Old Jul 11, 2006 | 11:38 PM
bobjoezx's Avatar
Default RE: help with triple trees needed
head bearings!???
Old Jul 14, 2006 | 03:59 AM
ray916mn's Avatar
Steering head bearings. Sounds like they aren't torqued enough or they are significantly flat spotted. They are critical to steering and stability and should always be replaced as a set. If the bike was in a severe enough accident to bend the triple trees, you should probably consider replacing the steering head bearings if you haven't already..They need to be torqued just enough so that when the front wheel is raised off the ground with the steering pointed straight ahead, lightly nudging the bars to either side causes the steering to flop against the steering stop.
Steering head bearing failure is very ugly. If they fail they typically lock the steering in a single position causing a crash due to lack of steering.
Old Jul 14, 2006 | 04:49 PM
David96Z's Avatar
sounds to me like the front end is no tightened down enough
CBRian1k
Aug 16, 2010 10:57 PM
twonis
Jan 6, 2009 10:17 AM
bajaroots
Jul 4, 2008 04:45 PM
