headlights quit working??
Old 08-24-2006, 12:59 AM
02_954rr's Avatar
Default headlights quit working??
i have a 2002 954 and my headlights are not working at all,curios if you guys out there might have some ideas,fuses ok,blinkers, tailights all work,any one know what it might be?
Old 08-24-2006, 01:07 AM
Default RE: headlights quit working??
if u knoe how to use a volt meter see if it gets any voltage to it...if not start trace the wiring back to the fuse box then switch......did it just suddenly stop?
Old 08-24-2006, 01:17 AM
02_954rr's Avatar
no never have used one good time to learn i gueese,yeah just all of a sudden,do the switches go bad?
Old 08-24-2006, 01:23 AM
or mayb a test light should b alright but i like using a volt meter....let me knoe wah u can got to use and i can explain wah u can check....IM me at wackyazn on AIM...
Old 08-24-2006, 01:30 AM
bobjoezx's Avatar
..... the BULBS......
Old 08-24-2006, 02:23 AM
02_954rr's Avatar
i well let you know ill test tommorow just start with the plug that goes in the back off the headlight and go from there,no not the bulbs tried a new one and nothing
Old 08-24-2006, 09:51 PM
hopefully it might b a blub if not let me knoe
Old 08-24-2006, 11:04 PM
bobjoezx's Avatar
use a test light at the fuse panel...
Old 08-25-2006, 01:49 AM
02_954rr's Avatar
i never got the chance to work on it today ill do it tommorow,no not the bulbs i wish,so test it at the fuse box?
Old 08-26-2006, 12:25 AM
test and see if power is commin into the light socket first....then work ur way back to the fuse box
Quick Reply: headlights quit working??
