H-vix valve and air box flapper
Has anyone gutted the h-vix valve in the mid pipe and remove the airbox flapper? what where results if you have?
RE: H-vix valve and air box flapper
I ended up with a slight flat spot just off of idle, and the idle got a little rough. I still have to reprogram the power commander to take care of that, which will be a pain, have to go and set up an appt to put it on the dyno. Other than that I haven't noticed any performance gains at all.
Gut the air box and remove the snorkels, install race air filter and new plugs (if not already) install PCIII, -1 tooth on counter sprocket, DYNO it and leave the HTEV alone.
2 Attachment(s)
ORIGINAL: kamikaze2899 I ended up with a slight flat spot just off of idle, and the idle got a little rough. I still have to reprogram the power commander to take care of that, which will be a pain, have to go and set up an appt to put it on the dyno. Other than that I haven't noticed any performance gains at all. Attachment 65482 Attachment 65483 |
Yhea I've removed the Flapper asembly, cables, and installed a BMC race filter. I'm still thinking about removing the snorkels though?? I also removed the exhaust valve and replaced it with a Hass type eliminator that I made at work. Still gotta cut the Micron pipe down about 6in. And the PC IIIr should be here tomarrow according to UPS. I'll let you know when I get her fired up. Still searching for a decent map, may go with a tweeked version of the 110-005 map on dynojets web site till spring. Oh yhea forgot about the PAIR block-offs. Did them too.
what does removing the snorkles help??? (still new to the sport bike thing) i just installed my powercommander III need to update map. and tweek.... about how much does a dyno tune cost est??
$250 around here. Still waitin on the income tax to get that done.
let us know how the tuning goes with the snorkles, and flapper removed....
Check out this site directly from Honda. This confirms the reasoning for the flapper and HTEV are environmental for noise reduction.
Honda Worldwide | Noise Reduction |
i have the hvix removed, but the flapper is still there and hooked to the cables, and so are the snorkels.. should i remove them?
| All times are GMT -5. The time now is 06:06 AM. |
