GSX-R 750 brake question
I know yall are probably going to chew me out for asking a question about a gixxer in here but: Today i decided to go for a ride on my wifes gixxer[:@] and when I attempted to push in the rear brake lever, it went all the way down, without stopping the bike. I have a better chance stopping the bike flinstone style. I immediately turned around and came home. I tried it in the driveway a few times and I can feel it engage slightly, butit wont even hold the bike from rolling backwards. I checked the fluids (good). Im sure its a way to adjust, that are pretty similar on all bikes. Can someone help me out? (Bobjoe)
. The honda should be here in less than 3 weeks.
if you look at the rear-set for the r/side-some where in that area-you should see a cylinder that has the line
going to the rear caliper-also,look at the rear brake fluid reservoir and follow it down-basically the same thing!
-the rear brakes are completely independent from the front-i would recommend bleeding the system first!
once you really look at it-it is simple-sportbike rear brakes utilize a very small area!
if you need help with the bleeding process,just do this-get a wrench that fits the bleeder screw(it should have a
rubber cap on it-remove the cap!)-activate the brake-loosen the bleeder screw-air or fluid should come out,do this
while the brake is activated-hold the peg down!!-tighten the screw,then release the brake peg-move it up/down
a bunch of times-then repeat!!-the trick is this-DO NOT OPEN THE BLEEDER SCREW-THEN RELEASE THE BRAKE PEDAL-
KEEP THE PEDAL DOWN!!!-the target is to have resistance in the rear brake pedal,loosen the screw-then feel the
pedal go to the floor!
i hope this helps you!
o8
damn!!-this reply looks like sh*t-i guess there is a difference when using apple computers!!
o8
bled for maybe 10 mins. brake lever down, loosen screw, tighten screw, released lever, pumped lever 15 to 20 times. small amounts of fluid came out each time.repeated about 10 times. stopped when i felt no gaining resistance. Did I stop too soon? all connections appear to be tight/ leak free but i really dont know what i should be looking for.
