Getting stock lowering link off!
Old Sep 4, 2008 | 04:02 AM
djblaze247's Avatar
Default Getting stock lowering link off!
Need some tips on getting the actual stock link off my 954, I ordered the link and not the triangles and ran into a slight speed bump. I can't get the stock link off because the I can't slide the upper bolt out because it hits the exhaust bracket which is a part of the actual bike frame. Any help would greatly appreciated.
Old Sep 4, 2008 | 09:59 AM
not_agn's Avatar
Default RE: Getting stock lowering link off!
I pushed the rubber grommet out and the bolt should fit through. Of course I had a micron full system so I didn't use that mount anymore. If you have the stock exhaust you just need to move it out of the way and remover the rubber. Then reinstall and mount you exhaust.
Old Sep 4, 2008 | 01:33 PM
Bert's Avatar
yeah i did the same thing you need to get the rubber piece off and it will slide through.
Old Sep 8, 2008 | 11:09 AM
djblaze247's Avatar
Thanx for the tip, that worked perfectly, my link also has a 4 inch setting but I can't get it there because the shock hits the link at that point so I have it dropped 2 inches. any tips of how to get it to the 4inch setting?
jtboyd91
Jul 23, 2010 08:24 PM
Handan
Oct 27, 2006 07:52 PM
delta
Apr 4, 2006 03:27 PM
