Fuel pump not priming plz help
Old Jan 7, 2024 | 02:19 PM
kratos954cc's Avatar
Default Fuel pump not priming plz help
Ok so I have a 2002 954rr that I’m rebuilding old motor blew I replaced the motor and decided to do the wiring harness put it in and everything is plugged in and in the right spot all the fuses are ok as well well pump won’t prime so I looked around and the fuel cut of relay won’t click I don’t know if that was it but if anybody can help me plz do
Old Jan 7, 2024 | 05:43 PM
Mamba954's Avatar
You check the fuse
Old Jan 7, 2024 | 06:45 PM
Most likely, as in 99.99%
I thought the 954rr didn’t have that little fuse on the starter solenoid thought only the 929 but if so I didn’t see that on mine maybe forgot to put it on I’m guessing that lil fuse has something woth the fuel pump
Old Jan 8, 2024 | 11:13 PM
1. unplugged everything from harness
2. removed harness from bike
3.put new harness in and route
4.plugged everything in correctly
5.
... etc...
Everything is correct spot all the plugs are mark and color codes so I won’t forget what goes where it fuel cut off relay Is not clicking and there is power to the fuel pump but not prime and yes it’s a brand new pump
Old Jan 9, 2024 | 06:47 PM
rockpool's Avatar
Was the fuel pump priming on the bike that you took the harness off?
Old Jan 19, 2024 | 08:57 AM
74demon's Avatar
Check your wiring diagram. The fuel pump connector is the same as the speed sensor. They can easily get crossed.
TC74
Aug 8, 2017 03:52 PM
bowflexmaverick
Jul 19, 2015 10:33 AM
tbow
May 16, 2012 12:22 PM
Eudabusa
Oct 21, 2010 05:46 AM
oldschoolCBR
Apr 16, 2007 11:56 AM
