fuel pump
I used the search option on fuel pumps but nothing came up...so I'll go ahead and post my problem. Today when I was riding back from work about halfway home my bike kind of lurched, like I hit something or the back tire locked up and then kept going....but nothing real bad happened so I assumed everything was fine and kept going home. Well, a couple hours later when I went to go ride a couple roads to cool me off I turned the ignition to "on" and the fuel pump didn't start. I tried to start the bike, and nothing happened. So I turned the bike off and back on and tried to start the bike, still no fuel pump sound, and no start. Sooo my question is: Do you guys think this is the actual fuel pump or something else around the fuel lines? And how 'easy' would it be to fix this problem by myself?
dude the exact same thing just happened to me this summer and it took me months to figure out the problem. So before you go and waste loads of time and spend any money on a fuel pump, relays, wiring harness or anything, do this. In front of your guage cluster, behind your headlights, underneath your windscreen, locate a white electronic "plug-in" connector. It is the type of connector that connects two wiring harnesses. It should be the only white one in that area. I dont know exactly what it is but after spending hours upon hours and dollars upon dollars of searching for the problem,it turned out to be an electronic connection involving this connector. All I did was just play with it and reposition it and my bike started perfectly everytime. If repositioning it doesnt work, take it apart and clean it. Before I figured out what the problem was with my bike, I would turnit onand the fuel pump wouldnt prime, just like yours isnt. It got to the point where I would turn the key on and my fuel pump wouldnt prime, my headlights wouldnt come on and my guage cluster wouldnt light up. I then started playing with those wires including that white connector and the bike ran perfect ever since.
PS if it turns out not to be that connector let me know. I have a perfectly good fuel pump ANDand fuel pumprelay sitting in a box in my garage that I dont need. Im sure we can make some sort of deal. Email me Chrisct713@hotmail.com (or anyone else that may be interested!)
Chrisct723 I have that exact problem, my cluster won't light up and the headlights don't turn on or anything like that. I'll check it out ASAP and get back with you, but it seems like you just saved me a lot of time and money!!
So today I went to check out the wiring harnesses and it was just a big mass of chaos. I've got a few pics that I took with my phone to show what's going on....there's a couple of connectors that look like they're supposed to do something but they've been kinda left alone...i couldn't tell what was supposed to be white or yellow because the dude who had the bike before me must have messed up the front end or something and redid everything himself...at least the tape job doesn't look professional at all...
alright here we go again...
first picture was taken from the right hand side of the bike looking down through the handlebar behind the windscreen, second picture was taken from the left, third was taken from the center looking straight down, fourth was a random hanging wire with two connector looking things that was attatched to my left handlebar, and the last one was another random connector kind of in the center that was taped against the back of my headlight....
[IMG]local://upfiles/12659/570DDFE87AEA48389693AA75EE8D4776.jpg[/IMG]
[IMG]local://upfiles/12659/8AAAA99DECD449EF9B2004013571BC3B.jpg[/IMG]
[IMG]local://upfiles/12659/50123FB10FC74BD180F0FB1CD11509E5.jpg[/IMG]
[IMG]local://upfiles/12659/9A5D3F3AABC847B6BF8A04E97893FFCE.jpg[/IMG]
[IMG]local://upfiles/12659/5743C11ECCC44BFE80A5D0438C7A918D.jpg[/IMG]
