feedback on my hids !!
I use my brights so little that, I didn't see the point in buying HID's for them. Plus on the buell I have a flash to pass button, which I use often and that's not going to work well with a HID.
I ended up sticking the ballast on the right side under the air scoop. Took the right side fairing off and stuck it to the inside of the inner fairing with double sided tape.
Well that sucks, I have a 35w 8000k on the way for my low beam. I just tinted my headlight too..... Wonder how thats going to shine.... anybody?
What? I thought the low beam was 55w?
Retro Solutions will not even warrant their lifetime warrenty Bi-Xenon projector conversion kits if you switch from 35W to 55W.
mine do the same thing, lights out till about 50 feet out then stops. the ambient light that you dont see still light up street signs a mile away like letsride said...at any rate they are still brighter than my factory headlights. i have a 6k.
Has anyone tried to install this single projector kit in the low beam housing?
motorcycle hid projector KT-MT3
They don't say how it installs, but I'm assuming you need to remove the headlight lens and it just sits in the stock halogen reflector housing.
I see hid projector kits for the 954, but they are all dual kits that replace the high beams.
