feedback on my hids !!
Old Apr 29, 2011 | 10:46 PM
moses25's Avatar
Default feedback on my hids !!
i must say i love the color but the first thing i noticed with my 8k hid light is that its light span is much wider of a span than stock but its straight out distance is terrible and u cant adjust the bulb itself cause it only sits in the light one way!!! or can they be adjusted ????
Old Apr 30, 2011 | 12:09 AM
letsride's Avatar
I have 5k and I don't have that problem.Mine with illuminate signs about a mile away.
Old Apr 30, 2011 | 12:46 AM
moses25's Avatar
its weird its like its bright as **** for 10 feet and then its completley dark
Old Apr 30, 2011 | 01:02 AM
Ls1Tuner_06's Avatar
something can't be right. got any way to show us some pics when u get a chance?
Old Apr 30, 2011 | 03:47 PM
moosestang's Avatar
there is a way to adjust the entire headlight housing, it's in the manual somewhere.
Old Apr 30, 2011 | 05:42 PM
Conrice's Avatar
no... thats HID's nature. thats why most of HID kit providers recommend using a projector light.
Old Apr 30, 2011 | 07:08 PM
moosestang's Avatar
Where did everyone put their ballast? Also did you plug the bulb leads into the stock connector or did you cut it off? My stock connector seems a little loose when i plug the leads from the ddm tuning kit into it. 3k left, 5 or 6k right, can't remember. I see what you mean about cutting the corners off the plastic piece that goes on the back of the bulb.
Old Apr 30, 2011 | 07:24 PM
moosestang's Avatar
Moses, your bulb is sitting in there straight, right? You cut the corners off the plastic piece that pushes on the back of the bulb?
Old Apr 30, 2011 | 10:21 PM
moses25's Avatar
yes its in there straight i and as far as your leads go i actualy pluged them into the cannon plug that comes off ur stock buld the connected that into the actuall connector and i found that too be much tighter !!! what i would like too know is if i choose too run all three of my lights with the hids were the hell would i fit all that wiring and ballasts lol
Old Apr 30, 2011 | 10:30 PM
letsride's Avatar
I mounted them under the air scoops.2 on the left and 1 on the right by the radiator.Mounted them using velcro.
