Cooling fan temp setting
Does anyone know a way to change the temp setting that the cooling fan kicks on? I know mine kicks on around 215°F, would really like it to be around 200°F. Don't know if anyone has the same problem as me with mine, but it doesn't start very well when its hot.
Originally Posted by shawnee_cbr
(Post 1225960)
^^^^^^^ this
Yeah I thought about installing a switch, but I don't want to drill a hole or install a bracket on my baby. I would rather have a preset temp setting of 200°F if possible
I'm pretty sure you can replace the thermostat with one that activates earlier. At least I remember reading that somewhere.
Originally Posted by DefconZero
(Post 1226044)
(Post 1226044)
if you put a lower T stat in the only thing that's gonna do is reduce your tendency to detonate in the cylinder resulting in un burnt fuel and the fan will still kick on at the temps they are now |
i took my horn out/off (i've never once used it). so i took out the switch, bought a new switch (not momentary like the horn's switch) and wired it up to kick on the fan. basically, you just want to add a hot wire to the system - the switch makes/brakes it. jacket the hot wire to the plug (or a quick connect to the wire) and the fan will kick on like normal or you can turn it on whenever you feel like it.
Hey conrice,what kind of switch did you use? Any pics?
1 Attachment(s)
Originally Posted by letsride
(Post 1226282)
Attachment 33736 you can barely see it, i know.... but that lil red button is it. i did have to epoxy a small area right around it to make it fit in there - but after i sanded and buffed it, i painted it black and it looked good. it was just a universal switch from radio shack. |
| All times are GMT -5. The time now is 07:24 AM. |
