cooling fan comes on at 100 degrees and lower ?
Old Sep 15, 2005 | 10:19 AM
03954guy's Avatar
Default cooling fan comes on at 100 degrees and lower ?
last night i went riding around it was about 68 dehrees out and rolling down high way in 6th gear finally came to a light looked down temp guage is at 88 and at around 94 degrees the fan comes on it usually doesn't come on until like 210 dehrees is this normal becuase of the cooler temp outside or is this like a f'ed up relay for the fan or a coolant temp switch or something of that nature any input greatly appreciated
Old Sep 15, 2005 | 03:15 PM
rr954ryder's Avatar
Default RE: cooling fan comes on at 100 degrees and lower ?
have you made shure that the temp is on F, not C. if that is not the case then you might have a bad temp switch or temp sender.
Old Sep 15, 2005 | 06:54 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Ya, you gotta be set on C's -- 94C = 202F.
Old Sep 19, 2005 | 07:53 PM
03954guy's Avatar
wow don't i feel like a jack *** little c sitting right next to the numbers thanks i'm glad nothing is actually ****ed up
Old Sep 21, 2005 | 02:56 AM
rr954ryder's Avatar
that's cool. it happened to one of my buddies too. just hold down the right button and it will go back. we all have blonde moments sometimes
BBirish
Feb 14, 2011 03:19 PM
ta8218
Jan 10, 2009 10:35 PM
polemides
Dec 18, 2007 09:09 PM
WhiteTailCBR
Jun 13, 2005 02:28 AM
