considering an 02 954 ?? should I??
Old May 23, 2013 | 03:30 PM
rhino8648's Avatar
Default considering an 02 954 ?? should I??
looked at a 2002 cbr 954 for 4k
power commander
lowered front and rear
Bolt on swing arm extensions ( coming off immediately )
mild cam
new rear tire
snake print Corbin seat (yuk)
also considering the repsol faring kit from eBay (china) anyone done this any feed back ??
Old May 24, 2013 | 03:47 PM
Hudson's Avatar
what country are you in and what is the mileage.... would not bother with the chinese parts they are often junk.
Old May 24, 2013 | 03:59 PM
rhino8648's Avatar
Im in USA dallas texas to b exact and the milage is around 13000-14000
Old May 24, 2013 | 04:21 PM
Conrice's Avatar
"mild cam"
and no aftermarket exhaust.... or anything else
sure.......
got a link on the CL ad?
as of right now, i'd say no way to $4k
Old May 24, 2013 | 04:43 PM
rhino8648's Avatar
has a after market pipe on it but he bought it that way so not sure what brand.
The CL link is down but I can email a few pics I have taken if that will help
Old May 24, 2013 | 04:44 PM
rhino8648's Avatar
That's a pic of it with the silver tank what is a reasonable price for this ?
Old May 24, 2013 | 04:56 PM
rhino8648's Avatar
or should I pass on it all together
Old May 24, 2013 | 05:16 PM
Conrice's Avatar
not even close with the mis-matched fairings. it's most likely been wrecked. (look at frame, pegs, bar ends, misc bolts to see if you can figure out how it fell)
i dig the exhaust though...you gotta find out what the deal is with the cam and other modifications - because a cam should be pretty far down the mod list - a lot of stuff comes before you do cams
for me, it's ALL about condition - more so than what's been done to it, what it looks like, miles, etc.
id say if it's a great bike mechanically (the guy knows his stuff, he has maintained it, chain and sprockets are good, etc) - no more than $3200 or so...
and then make back some of the stuff that you don't like by selling it. i'm sure it has an adjustable dogbone - those can sell pretty quick and the extensions are worth some dough...
check a few things - sprockets, front and rear brake calipers. the sprockets should look clean and the chain should have about 1 3/4 inches of play. look for excessive brake dust, check the pads, see how much pad is left, bend down and see if you can see the pistons, what do they look like, etc.
whats the front of the radiator look like? are the fins in good shape?
look at the fork legs. make sure the dust caps look pretty even and make sure there is not any fork oil leaking (obviously)
check for mechanical noises. make sure when you go and look at it, that it's cold. not warm. it should start up pretty quick. listen for mechanical noises that aren't right (piston slap, rod nocks, cam chain rattle). watch the bike go through the whole heat cycle. turn it off. let it set for a minute. start it again. obviously look for smoke out of the pipe. take it for a ride. make sure it pulls strong through some rpms. make sure it can shift smoothly into and out of all gears.
you know, look for the normal stuff.
a bike that's lowered and stretched is real easy to whack open the throttle on, so i'd be looking for some sort of signs of being abused. that doesn't mean it was though
Old May 24, 2013 | 05:22 PM
Conrice's Avatar
OH, i almost forgot.
check underneath the front nose fairing and fender. with a lowered bike like that - you can bet that the front fender and nose fairing have made contact on heavy braking.
make sure the inner fairings are in place too. the nose fairing bottoming out of the fender can/will knock those out of place.
those are two very good indicators of how this bike was used.
