Cbr 1000 front end swap
Old Jul 31, 2011 | 10:42 PM
javan1's Avatar
Default Cbr 1000 front end swap
Hello I was just wondering if anyone new if the triple tree is the same or will work in the 929/954 frame and if the breaks are the same dia or if you would need the front wheel off the 1000 also , thanks
Old Aug 1, 2011 | 08:57 AM
Conrice's Avatar
if you want to swap for a 1krr front end, thats doable, however, the brake rotor dia is different, as well, the rotor offset, axle length, front rim, brake calipers etc. is all different, so if you're going to swap, you need to swap the entire front end, not just forks.
http://www.allballsracing.com/index.php/forkconvertion this will shed some light on what you can do.
midnightsparks
Mar 11, 2011 03:13 PM
gordo993
F2 Tech
Jun 8, 2010 06:25 PM
gotfear
Jun 30, 2009 01:11 PM
gotfear
Apr 9, 2009 08:49 PM
racerrick
Nov 7, 2007 07:31 PM
