Call me Crazy but the swingarm is aluminum...right?
Old Jun 18, 2008 | 11:00 PM
Wildcard's Avatar
Default Call me Crazy but the swingarm is aluminum...right?
Just asking if the 54 swingarm is aluminum because I got some Mother Aluminum and Mag cleaner today to use on it and I got no black residue to appear as the instructions say I should. It actually says to quit using it as it is not a polishable metal if you don't get a black residue. Is there some sort of coating over the aluminum or something? All I did was clean it up and run some steel whool over to see how long and hard the polishing process would take. I used a #3, #1, #00, then #0000. It appeared real clean so I put the mothers on and no black residue, so they are aluminum right...or am I missing something?
wildcard
Old Jun 18, 2008 | 11:02 PM
PlayfulGod's Avatar
Default RE: Call me Crazy but the swingarm is aluminum...right?
it maybe clearcoated.
Old Jun 18, 2008 | 11:06 PM
Wildcard's Avatar
I was thinking that, but wouldn't the steel wool remove the clear coat? I didn't spend an eternity on it, about 15 minutes per grade, but I only scrubbed a small section as a "test" area. So I was thinking the clear coat should be removed from the area. This makes me wonder, I was looking towards doing the rims this weekend and just wanted all my ducks in a row first, ya know?
wildcard
Old Jun 18, 2008 | 11:15 PM
PlayfulGod's Avatar
clearcoat can be some hard stuff. Seems like ya shoulda been thru it tho. work on it a bit more n see if it starts doing right.
Old Jun 19, 2008 | 12:58 AM
cbrRick954's Avatar
a little hard work never killed anyone...but why chance it?
lol
Old Jun 19, 2008 | 02:03 PM
zoniebutt's Avatar
i did mine by wet sanding but i went up to 2000 grit u gotta rub the mothers in and it becomes black then whipre it off should blinggggg
Old Jun 19, 2008 | 02:25 PM
NastyNINA54's Avatar
a guy i know does polishing as a side gig, and he told me that he has to sand it down with a few differant grits, then uses 2000 grit and then buffs with the mothers. from what he said it sounds like it takes a while to do the whole process. maybe u just didnt do it long enuff. good luck with the polishing, its a biotch to keep up. i used to have a polished swingarm, and after cleaning and buffing everytime i washed it, i was too tired to ride the damn thing.
buzzy
Aug 1, 2012 01:26 PM
Wildcard
Aug 22, 2010 11:38 PM
SmokinJoe96
Jan 26, 2008 09:56 PM
steve00ses
Nov 6, 2006 02:17 AM
