brakes
Old Oct 31, 2007 | 02:05 AM
maninder's Avatar
Default brakes
why do my front brakes shudder and also noisy in wet weather??
Old Oct 31, 2007 | 02:07 AM
maninder's Avatar
Default RE: brakes
Why do front brakes shudder and are noisy in the rain?
Old Oct 31, 2007 | 02:11 AM
maninder's Avatar
Default RE: brakes
i am using EBC pads
Old Oct 31, 2007 | 06:48 AM
bobjoezx's Avatar
Default RE: brakes
shudder.. how hard.. check your rotors .. does it just do it in the wet? brakes do not like water.. they usually squeal a little in the rain
Old Oct 31, 2007 | 07:48 AM
maninder's Avatar
Default RE: brakes
a normal squeeze causes the shuddering
Old Oct 31, 2007 | 03:22 PM
bobjoezx's Avatar
Default RE: brakes
jsut in wet or all the time.. check your rotors
Old Oct 31, 2007 | 07:36 PM
TCIRACING's Avatar
Default RE: brakes
UR ROTOR'S WORN, CHECK THE THICKNESS.
GET A NEW SET OF ROTORS AND WHILE UR AT IT, PUT ON NEW PADS, AND WHILE UR AT IT, BLEED THE BRAKE LINES TOO, AND WHILE UR AT IT MAKE SURE THE BOLTS AND NUT ARE TIGHTEN TO THE TORQUE SPEC IN UR MANUAL..................
Old Oct 31, 2007 | 08:59 PM
VP's Avatar
VP
Default RE: brakes
ORIGINAL: TCIRACING
while ur at it
Old Oct 31, 2007 | 09:03 PM
bobjoezx's Avatar
Default RE: brakes
and steel lines
Old Oct 31, 2007 | 09:51 PM
letsride's Avatar
Default RE: brakes
and loose nut behind the wheel ha ha ha
