Brake fluid
Old Aug 17, 2007 | 11:15 AM
TCIRACING's Avatar
Default Brake fluid
Hey guys, how often do you change your brake fluid? Can you tell when to change by the color of the fluid, if getting changed, do you flush the whole lining or just suck out from the cup and refill with new ones?
Old Aug 17, 2007 | 01:18 PM
bobjoezx's Avatar
Default RE: Brake fluid
to do it the right way.. get steel lines and put brand new dot 4 fluid in there and bleed the lines
Old Aug 18, 2007 | 12:48 AM
richhowerton's Avatar
I change it every 2nd season and Yes pull the lines at the bottem. I blow the lines out using shop air and then fill and belld them down.
Old Aug 18, 2007 | 01:35 AM
demonchild's Avatar
i think the manual calls for every 12000 miles to flush the fluid.
Old Aug 20, 2007 | 06:09 AM
mark21901's Avatar
i change out rear brakes every 5k miles or less(galfers w/custum mount from myrtle cyclesmount will rub once get a couple months on it).so i bleed both then. if you dont have to theres not much sense doing it more than once every season...
johnnyx
Aug 22, 2012 01:15 PM
CJardine
Jul 24, 2012 09:41 AM
ThisisMickey
Aug 24, 2007 03:38 PM
tutman6
Aug 27, 2006 01:23 PM
hondacbr1000
Jul 22, 2006 06:41 PM
