blew a fork seal!
Old Mar 24, 2007 | 10:25 AM
salboy12's Avatar
Default blew a fork seal!
i blew a fork seal, but dont have time to fix it right away. would it be that harmful if i rode the bike for a day or two with a blown seal?? thanks
Old Mar 24, 2007 | 11:32 AM
bobjoezx's Avatar
Default RE: blew a fork seal!
yes you will leak oil all over your fork.. can get on tire and cause front tire to slip out.. take it in.. or make time if u want to ride
Old Mar 24, 2007 | 02:18 PM
alekinci's Avatar
your ride will become stiff as hell and the bike will sway toward one sideconstantly.
i recommend not to ride it, but getting it fixed is pricey. most people on these forums like the f4i and the RR say its an easy but long process.i cant say that it will be easy for sure since i have never done it.good luck
Old Mar 24, 2007 | 02:37 PM
bobjoezx's Avatar
i would fix it asap
http://www.sportrider.com/tech/146_9906_fork_seals/
Old Mar 29, 2007 | 01:07 AM
jcowick's Avatar
only 2 or 3 hundred bucks thats not too much for something that important is it??
Old Mar 29, 2007 | 01:10 AM
jcowick's Avatar
dont know about you guys but i work to damn much to worry about coming homeanddiving into some forkseals ill gladly let my local shop take the hassleoff my hands and not worry about it
Old Mar 29, 2007 | 03:30 AM
ssrdrifter's Avatar
By "blown" seal do you mean ther is a pool of fork oil on the floor under you fork, or is the seal leakingoil on the fork / bodywork? If it is leaking you have been riding on it for a bit. Yes it is a big deal and all but as long as you have oil in the fork and you are just leaking on the fork tube, you are not going to harm anythig with a few more miles. Make sure there is no visible damage to the fork that may have damaged the seal in the first place.I live in so cal and it cost me something around $220.00 to have both seals replaced. I would advise to fix it asap but if you find oil on your fork tube in the middle of a sunday ride, I would not call for a truck to pick me up if you follow....
Old Mar 29, 2007 | 03:01 PM
RYDINRED929's Avatar
i just pulled my forks off and took them to the shop to have the seals replaced.. it takes about an hour to take the forks off and the price lowers from 250 to 90 bucks...
Old Mar 29, 2007 | 03:59 PM
bobjoezx's Avatar
good idea, do have the work... save alot of money.. good thiking
Old Sep 19, 2007 | 04:10 AM
sUshI's Avatar
so..is there a step by step how to diy?? My right seal is leakin..kinda.. I did a search..a half assed search mind you.thought Id ask anyways..holla!!
