BIKE HEIGHT CHANGE??
Old May 13, 2008 | 07:39 PM
TMcNally954's Avatar
Default RE: BIKE HEIGHT CHANGE??
where can i get a stock "dogbone" and how much? is that the traingle looking peice with the 3 bolts in it?
Old May 13, 2008 | 11:26 PM
bignibb's Avatar
Permanent ROTM Nominee
its not the triangle its the piece the triangle is connected to
well with with the one you have I believe one of the three setting is the stock height setting.
now on the picture you posted with the triangle
you see the triangle and this stick with a hole passing through it with the hole on the left
there are three holes
yours is in the middle hole if you move it to the right hole
you will have two holes on the left and you would be in third hole
the farthest to the right and that should raise it back to stock height.
the good news is someone else already did the hard part of installing the dog bone
you and a friend should be able to get it back to stock height no problem!
Old May 16, 2008 | 11:52 AM
how do i take the tension off of the dogbone to get the bolt out of it? i unscrewed the bolt on the side of it. but its very hard to pull the bolt out... how do i support the dogbone? or whatever it is i need to support to get the bolt out? thanks alot.
Old May 16, 2008 | 01:52 PM
TK954RR's Avatar
Jan 2009 ROTM
To do this job you will want to have a friend or 2 around, especially if you are going to do the front also. Just have a guy or 2 lift up the tail a bit while you pull the bolt and reinsert into the proper hole. If you dont have friends then a couple of ratchet straps and ceiling joices are going to be your best bet.
Old May 16, 2008 | 01:59 PM
well even with the swingarm off the ground it seems very tight. should i just use a deadblow hammer and punch it out the other side? it seems just as hard to get the bolt out while the bike is on the stand then it does with the bike off the ground?
i just didnt want to pull that bolt out and not be able to move the triangle peice to the other hole, or have the weight of the bike come down and me not be able to get the bolt in any of the holes
Old May 16, 2008 | 08:12 PM
YAM93's Avatar
There's a balance point that the bolt should come out with minimal force at. It should be at some happy medium point between fully weighted and fully extended. In other words, hang it from a ceiling joist with straps around the pegs and frame if possible, then have a friend (or use some 2x10's stacked incrementally) raise the rear wheel a board at a time until the bolt comes out easy.
Don't force it too much, but worse case scenario you can persuade it slowly with a plastic faced hammer. Be careful not to shred the threads of the bolt doing this.
Old May 16, 2008 | 09:59 PM
well hanging it from the celing is out of the question, dont have good enough straps, a good spot to do it... if i cut 2, 2X4's equal length and long enough so that me and a buddy can lift the back up and put the 2x4's up under the swing arm, basically working as a bike stand.. wouldnt that work? i tried it, but it still didnt seem to want to come out real easy...
Old May 21, 2008 | 05:54 PM
Wildcard's Avatar
Well here is the link I put in my bike last week. Hopefully it'll help clarify a bit. It's a little cleaner than the otehr picture.
wildcard
Old May 21, 2008 | 08:19 PM
Wildcard's Avatar
And I believe we we "tapped"it with the butt end of a screwdriver as it seemed to have been bound up with crud. Your bike looks as though it may have been bound up by weather elements too, so you might have to tap it with something to get it broke free. After that it should be fairly easy to remove and reinstall the other bone. I definately reccomend having someone there to help. Mine was strapped to a rafter, although there are other ways to do it, but working smarter and safer are definately above working harder!
wildcard
Old May 21, 2008 | 08:26 PM
stunter411's Avatar
ORIGINAL: TMcNally954
here are the pics, hope they help
ok while we are at this ride height how do u guys move the suspencions couple clicks up + with out the little wrench that u get with the bike??? ( i am talking about the 1st picture)
