cheap diagnostic
Originally Posted by cBrentb
(Post 1255208)
Thanks for all the help. I'm about to do a compression and leak down test.
When rev it at idle its more like a ploom of smoke. Also, right after revving, I can barely see it but, at idle its smoking some too, if I use a light in the background I can see smoke on idle. I've double checked for spark. It has good spark at all four. The coil tips seem to be making contact even though I havnt ried bending them out yet. As far as vacuum check, I've had the throttle bodies off and cleaned/ synced, I sealed all boots were they attach at motor and air box with black rtv, all vac lines look good and don't leak. I've sprayed nearly a whole can of carb cleaner around throttle bodies while running and find no leaks. Another thing is that it consumes a considerate amount of oil when I ride it, especially after rides at higher rpms. And spark plugs have signs of burnt oil (ashy white on the tips of two plugs) |
