A little update, I did a couple pulls on the dyno today and the two bros down load I put on the pc is still a crappy map, its slightly better than without, but not by much. I have to get a custom map.
ive found that the erion bolt on and oem or after market air filter down load is working best for my bike.
Originally Posted by cBrentb
(Post 1249578)
Have you looked at any of the values on the OEM maps? Are there a lot of -'s in front of the numbers? |
what do you mean oem maps? where can i find those? maybe you mean the the map it came with out of the box. there is a map number on the side of the pc box itself.
good point though. when i find some i'll check out the values and see if they are on the leaner side. |
I down loaded the completely stock map on the pc this morning. I can't believe the difference in the way it runs now! HUGE difference. I wasn't able to open it up all the way on the interstate be cause of a bald rear tire that is getting replaced this week. So I stayed on secondary roads. But, when I left home I imediatly notice how much smoother and responsive it was running. But, let me tell you how I found out exactly how much better its pulling now. Lol, I was in second gear about to pass a wehicle in front of me when I gunned like I normally do the front end came up with ease and a little head wobble (almost tank slapper)! Damn, I'm glad I can rest easy now. Hopefully this map will suffice until a custom tune. Now I know why one of the first mods people suggest on these bikes is a steering damper.
Finally figured out the full exhaust map down works best for my set up. I have the d&d full exhaust one on mine.
Good, how's she running now?
Test drove it last night and it was riding like ****. The fuel/ air ratios are off with the map I installed. I'll try another full exhaust I guess. Plugs were all messed up, looking fouled. Two had ashy white tips from lean. Thinkingit needs a custom map.
