929 to a 954 swingarm? help
Old Jul 14, 2012 | 05:44 PM
J0HNDiLLiNGER's Avatar
Default 929 to a 954 swingarm? help
i just got to restoring the 929, and i bought a red 954 swingarm but i never removed a swingarm befor! thers 2 giant alan key shape, 1 on each side of the rod like on the front rim. witch side is the bolt and witch sides the nut, i found something to use to turn it but unsure witch side to turn it from?
Old Jul 14, 2012 | 06:19 PM
74demon's Avatar
The nut is on the right hand side. Don't forget to loosen the pinch bolt before attempting to loosen that nut.
Old Jul 14, 2012 | 07:14 PM
thanx! so i should take the nut off first? im restoring same theme 929 as urs lol
Old Jul 14, 2012 | 07:30 PM
74demon's Avatar
First before what? Loosening the pinch bolts? You need to at least loosen the nut side so it will turn.
Why are you putting a 54 arm on it? I've never tried, but I read somewhere that its a little different. PM conrice, unless he chimes in. He may know for sure.
Let me know if you need any help or pics on it....
Old Jul 15, 2012 | 09:42 AM
Conrice's Avatar
it should go in no problems, but i've never done it before.
the reason i used to have concern was because i had to shave a considerable amount of material off the vfr on to fit my 954 motor, and another guy got his viffer arm to fit his 929 motor with a 5lb sledge hammer - which would lead me to believe they're slightly different. but i looked around and a lot of people have done the swap - and they all said it's a straight swap.
you need 954 triangles and 954 rear brake carrier as well
Old Jul 15, 2012 | 02:13 PM
besides the 954 has spools and stock placement for tire hugger it looks alot sharper and i found a red swingarm on ebay for $50 even though i had an extra 954 swingarm, it would cost more then $50 to paint it so i jus ****** the one off ebay.
929
954
Old Jul 15, 2012 | 02:25 PM
thanx conrice, love the 954 u got, actually had me thinking bout putting vfr swing on my 954.
wut the 929 looks like now, brace urself lol
parts i jus ordered off ebay, got about a month b4 fairings show up. good 0l hong kong shipping
been looking for red sprockets any1 have a link H00K me up, thanx again evry1
Old Jul 15, 2012 | 03:23 PM
74demon's Avatar
Paint yours....
Old Jul 15, 2012 | 03:33 PM
Paint yours....
lol no man, i dont paint i turn wrenches and let some1 else be responsable for the finishing touch. i always had a problem with runs
Old Jul 15, 2012 | 03:37 PM
74demon's Avatar
It's just a sprocket. I turn wrenches too, but I managed to spray mine black. Just cleaned it up and used engine paint.
