3000 rpm bike has a different sound
Old Sep 20, 2011 | 08:51 AM
brad21803's Avatar
Default 3000 rpm bike has a different sound
Got a question...not a big issue but if its fixable.........I've had this bike a few months now and ever since I've had it, when riding, it doesn't matter what gear I'm in but when it hits right on the 3k rpm mark, it goes from a higher sound to a deeper sound. No change in power or performance. Don't really hear on heavy acceleration. I've changed the plugs in it a while back but no difference. But like I said, no big problem but if there is anyone else that has delt with this issue, what is the solution. Thanks.
Old Sep 20, 2011 | 10:07 AM
Blues48's Avatar
I think they all do that. I forget the reason, but mind does it too.
Old Sep 20, 2011 | 03:16 PM
brad21803's Avatar
Wow. That's blows. Did not know that. Not a big deal but gets a little annoying. Thanks for the feed back.
Old Sep 20, 2011 | 07:56 PM
moosestang's Avatar
A balanced and blueprinted rebuild will fix it right up! You go by that spot in the rpms so fast on hard acceleration that you don't feel it.
Old Sep 20, 2011 | 08:24 PM
backdoc's Avatar
This is normal operation of the servo motor that controls the flapper in the airbox and the exhaust valve. When the flapper in the airbox opens you will get increased intake noise. This is the change in sound you are hearing at 3k rpm.
Old Sep 20, 2011 | 11:38 PM
txsmainevent's Avatar
I wear earplugs now when i ride. i like the peacefulness of it..... but my servo is laced open and i have the servo removal module.
Old Sep 24, 2011 | 10:26 PM
losymis's Avatar
its your servo. also at around 7500 rpm it gets even louder. dont remove the servo (to sound deeper at lower rpms) because you will loose low end torque
Old Nov 11, 2011 | 11:46 AM
Starfire954's Avatar
It's normal noise(or music, imo). In traffic, with the tall 1st gear, I find myself pretty much in 1st gear a lot of the time. I'm slowly accelrating in 1st gear and I hear all the different sounds the bike makes as it goes through all the valve phases towards the higher rev range. I love it. My Yosh pipe and K&N really let me hear it all.
Old Nov 11, 2011 | 07:00 PM
moosestang's Avatar
Oh yeah, forgot about that.
woot
Jun 20, 2009 10:34 AM
aa87f4
Jul 3, 2008 03:41 PM
woot
Mar 31, 2008 02:30 PM
felk27t
Aug 1, 2007 02:46 AM
