tune up time
sup guys i pulled my spark plugs out. my bike has 16800 on it the plugs are denso iridium plugs . are thoes oem plugs? they look some what worn its soo hard to tell considering the electroide is so small. also i looked at all the intake vavles and the right and left outer ones have some gunk on them. all the inner ones are very clean . the throttle bodys are gumed up too . im going to use some throttle body cleaner tune up spray to clean them. why are only the outer intake valves gunked up and all inners are clean ? calling all cbr 929 engine experts out there ! lol
About the intake valves, I have absolutely no idea. So I will end it here!
yes they are the iuh27d plugs im going to get the 9 dollar plugs lol . i figured out why the valves were gummed up . i had the oil level too high . blow by from the case goes back in threw the airbox on the sides . thanks trey for the info on the plugs
i used 1/4 inch drive to 3/8 snap on wably spark plug socket it was easy thank god for snap on tools lol . did you notice a big difference with throttle responce after you did your plugs? considering mine were oem with 16800 miles im thinking it will be more responsive with new plugs im going to wait till about 20 k for the valves i only ride on weekends
Yeah i noticed it when I was running on 3 plugs and then I put 4 new ones in. I moved up from NGK CR9EHX-9 to the NGK CR9EHIX-9 and couldn't honestly say from new plugs to new plugs if there was a difference.
Awesome man. The NGK's are definately the way to go for the price. Denso's are just rediculously expensive.
