Steering Stabilizer?
Old Apr 2, 2008 | 04:47 PM
ReSpEcT's Avatar
Default RE: Steering Stabilizer?
Stearing head bearings are a common problem on 929/954's. I believe they may have even had a recall on those also...Steering stabilizer will make u fall in love all over again. Ever since i bought my $150 Scotts for my 929 and my 954, i'll never ride another bike without a stabilizer...It makes a world of difference and makes you feel like you have more control.....Mine has saved my azz a few times....=-)
Old Apr 2, 2008 | 04:58 PM
seldon929rr's Avatar
I have an ohlins and love it. +1 on never riding without a damper again. they are pricey but well worth the money. http://www.stuntlife.com/forums/464-...per-929-a.htmlcheck out this one. on the sound it's making at certain rpms what is the sound like? buzzing clicking, popping?
Old Apr 2, 2008 | 05:07 PM
bignibb's Avatar
Permanent ROTM Nominee
dagds10
i wanted to pm so not to clutter but if you could, would you post up your last six of your vin in the tread started by melathedd?
we're trying to see how limited the limited ERION racing edition is!
Old Apr 2, 2008 | 06:14 PM
bravehart's Avatar
you should get a damper, but you shouldnt have head shake all the time unless somethings wrong. as far as the buzzing noise do you have the stock exhaust valve still on? they are known to make noises at certain rpms.
Old Apr 2, 2008 | 08:29 PM
dagds10's Avatar
I beleive they are the stock valves, and the bike has 16,000 miles. The noise is buzzing kinda sound......but only around 3,700-4,000 rpm, anything over or under and she sounds fine.
Old Apr 2, 2008 | 09:12 PM
bravehart's Avatar
im sorry, i meant to say the htev bolted between the header and mid pipe
Old Apr 3, 2008 | 05:13 PM
ORIGINAL: dagds10
It might be a clipon or barend. mine always buzzes right before I lose a barend. anyone have a barend?
Old Apr 3, 2008 | 05:26 PM
bergs's Avatar
Check your head bearings before you dump 300 or moreof your hard-earned dollarsinto a steering damper.
I've seen head shake once on my 929 and I know exactly why it happened.
You shouldn't be having a reoccurring issue with head shake unless something is wrong.
The buzz is likely a loose fairing bolt. Go around and check for anything loose...even the mirrors and the black insert near the headers....check it all.
Old Apr 3, 2008 | 09:06 PM
dagds10's Avatar
LOOSE FRONT FENDER BOLT!!!!
That was the noise!! 1 turn and the noisewas gone!! The head bearings seemed tight, and the front end seemed to check out fine. The more i think about it, the more i think is was just me. I'm upgrading from a 91 CBR 600 F2....a heavier slower bike. I think the head shake is just me gettin used to a newer bike.
Thanks for all the help guys!!!!
Old Apr 3, 2008 | 11:49 PM
NY Erion929's Avatar
The easiest way to know if the neck bearings are bad is to slowly turn the handle bars back and forth and if you hear a randoom tiny little clicking noise, there bad
I just started hearing it on mine and the bearings actually just came here today from Carolinacycle.com... Gonna be putting them in before sunday hopefully
