Steering Stabilizer?
Hey guys
I got a 01 929 Erion edition, my first 929. I have two problems i'm hoping you guys can help me out with. The first one, "head shake". Mine is really really bad, hit the bars alittle and it feels like bike is going to come out from underneath me. Will a stabalizer solve that, and what one do you guys recomend. The second problem, is a weird sound. It sound like something is loose at 3,700-4,000rpm, but i've taken the tank and air box off and cant find anything loose. any ideas? Thanks for the inputs |
RE: Steering Stabilizer?
Congrats, and welcome to the club. We hope your stay will be long and happy. Part 1: Yes a steering damper will help and "any" will do. I have a Sprint and it works very well. Others have had good experience with Scotts, Ohlins, Arrow, and others. In part it will depend on your budget and the bling factor you are after. Want a 916-style or a steering head style? Then go from from there based on what you want to spend (expect to pay $300 - $700) Part 2: Loose fairing? Or plastic in the fairing? Mine had "lost" some of the little screwy-clippy things inside the fairing and rattled badly (since fixed). Is the noise more mechanical? These puppies are notoriously noisy... |
Maybe the bearings in the headtube are loose, get the front end off the ground somehow and see if there is any play.
Damn you guys are fast!! I just posted that like 10 min ago. HAHA
I bet thats it, Loose plastics!! A broken tab or something. Thanks for all the help guys! |
i found a used scotts damper for a DECENT price... i havent got to put much time on it yet, but the few spins around the block proved it was well worth the money!
Welcome to a club you will never want to leave! |
ORIGINAL: vwmaniacvr6 Maybe the bearings in the headtube are loose, get the front end off the ground somehow and see if there is any play. You shouldn't have a lot of head shake? I think you should inspect the front end on the bike. |
Yeah, I second the stabilizer! I got a used Scotts and I love it!! I'm glad you brought up the rattle too. I've noticed mine has the same buzz around 4-5K rpm. I just haven't spent much time to research it.....
I didn't read the buzz comment but yea mine has that also. It's a pain in the a$$. I was going to get a clip but never took the time to do it yet. Did that seem to cure the buzzing?
I haven't looked into the buzz yet, but a loose fairing sounds like the problem. I'll let you know where and how i fix it......if i can find it hahaha
If you say you a "really really bad" head shake problem it may be the neck bearings or a problem with the front end.
I wouldnt just slap a sterring damper on, inspect the front for any play , Then look into adding a damper |
