Stator Wire exposed
Stator Wire exposed
Hi! i bought a brand new Stator for a CBR 929rr installed it and charging system is still failing, bought a brand new R/R and still doing the same thing, so i pulled put my stator today and found this
For the looks of it, Its still looks good to me, but this wire that got exposed maybe is the culprit shortening the whole charging system! My Question is, if I wrap it with electirical tape on that exposed wire will i be able to fix this? my friend gave me that advice so im just trying to get a second Opinion, Thank you guys! and More power!! I love this site!
If the bare wire is touching the engine casing or anything that is directly connected to the negative terminal of the battery then you've got a short circuit, I.e the electrical power that should be going somewhere else is being shorted to ground (negative). Insulate all cables/wires correctly. Faults like this can leave you dead at the road side. Consider yourself lucky that you're still at home.
