servo motor
Old Jan 6, 2008 | 11:01 PM
goldenboy929's Avatar
Default servo motor
my exhaust servo motor constantly runs when bike is running or even when just the key is on does this mean it needs to be replaced?... it never did it for the first two weeks that i had it then when i had to have the main bearing replaced the guy said it was disconnected and my exhaust valve was fully closed so i should notice a huge difference but i didnt so is it even nessary?
Old Jan 7, 2008 | 09:55 AM
Eckl's Avatar
Default RE: servo motor
I would say that you would notice a difference in the higher RPM's, otherwise it would limit your exhaust flow reducing power. So are you saying your servo is spinning in either direction ALL the time when turned on? If so, I would say it needs replacing.
Old Jan 8, 2008 | 12:25 AM
ReSpEcT's Avatar
The servo motor will spit the FI code of 35 (90% of the time). Rarely do they go out and not spit the code. Mine was out but bike had poor response in higher RPM's.....=-)
Old Jan 8, 2008 | 12:34 AM
theres no code but it just makes this constant noise like its running all the time....but i dont feel a lose of power anywhereeven in high rpms so what should i do just replace it
Old Jan 8, 2008 | 02:13 AM
Eckl's Avatar
I would. Sounds like its on its way out anyways.
Old Jan 8, 2008 | 07:46 PM
ReSpEcT's Avatar
If its making noice constantly, then yeah u cant rule it out. I was just saying its rare to have it happen. No biggie if it is. Its easy to change out. Fairly cheap prices on ebay or in the classifieds. Just ask around and im sure u can get one cheap.....=-)
Old Jan 8, 2008 | 09:08 PM
RCR's Avatar
RCR
Thats why the guy before you unplugged it. It most likely is stuck on and thetroublecode is either notcatching it or he disabled it also.
Old Jan 9, 2008 | 09:07 AM
bignibb's Avatar
Permanent ROTM Nominee
I've been trying not to say anything concerning goldenboys situation because I just didn't want to be mean. I think the dealership ripped him off by by a lot and the bike ist even worth it. and now its having mechanical issues that it probally had before you purchased it, and this guy just smiles, and is happy as a kid in a candy store.
Old Jan 9, 2008 | 12:37 PM
Eckl's Avatar
Forget the HTEV altogether and order a Hass eliminator.... that is so long as you have a Power Commander I guess....
Old Jan 9, 2008 | 11:33 PM
bignibb's Avatar
that makes scense too, why replace it when you can just ditch it?
