Question for any mechanics
Old Jun 5, 2006 | 12:29 AM
lsu.tiger's Avatar
Default Question for any mechanics
Recently changed my pressure regulator because I was running rich (I thought it was busted). The problem got worse. I openned the airbox to see oil on the bottom. My oil level is now far higher than it was before. Is there any way that fuel and oil can get crossed and fuel can leak into the engine oil?...or oil into the air box?
I'm getting nothing but smoke out of my pipe and when it idles, RPM's drop and it kills.
Any ideas?
Old Jun 8, 2006 | 09:44 PM
TweakedCBR929RR's Avatar
Default RE: Question for any mechanics
I am by no meens a mechanic but it sounds to me like you have some bad piston rings causing pressure drop. as for oil in the airbox, i'm not to sure. I hope someone other then me can help you out. g'luck.
Old Jun 8, 2006 | 10:21 PM
lsu.tiger's Avatar
Thanks.
I found the problem.
In case anyone cares, here's my theory.
I had a bad fuel pressure regulator that's been getting worse for the past 4 months. I've been working on it and starting and stopping the bike without taking it on the road (so I never checked the oil level). The fuel pump was pumping fuel right past the cylinders (#1 and #4) without a regulator to slow it down. There wasn't enough air for combustion while it idled, so the fuel went straight past the cylinder and seeped into the engine oil.
When I finally changed the regulator, I noticed my oil level was high - really high. About 1 gallon of fuel got into the engine oil. After I changed the fuel regulator, the oil and filter, the bike ran like the day I bought it. Took me 4 months, but the problem is solved.
Thanks again for the help.
Old Jun 9, 2006 | 01:53 AM
1000RR's Avatar
ORIGINAL: lsu.tiger
Thanks.
I would feel better (if it was my bike) if I changed the oil again right away. Fuel is a killer, and will destroy oil. Even doing an oil change, you are still leaving almost a litre of old contaminated oil in the motor... it sits on the cams/valves etc and cannot drain.
I'd want the fresh oil to circulate, mix with the (little bit) of remaining old oil and flush it again.
I would definatly do this to be nice to my bearings at 10,000+rpms.
Old Jun 9, 2006 | 04:58 AM
Eddie1000rr's Avatar
I had a van that happend to once...didint know what it was at 1st thought it just needed its throat cleared from sitting so im holdin it at like 2500 rpm annnnnnnnnddddddd the muffler started on fire lol
Old Jun 9, 2006 | 02:51 PM
ericmxzx440's Avatar
Buy the cheapest oil and do about 3 to 4 oil changes. Put the oil in and start the bike for a few min and dump. Same thing again. Like 1000rr said.. gas and oil are not friends. You can burn the rings up quick with gas in the oil. Good Luck!!
Old Jun 9, 2006 | 09:22 PM
lsu.tiger's Avatar
I will.
Are there any indications you know of that I may have done damage already?
Thanks.
Old Jun 10, 2006 | 11:19 AM
Compression test!
Old Jun 18, 2006 | 03:48 AM
Rx7man's Avatar
same thing happened to my katana, except it had been sitting for a year, and a bad float needle, or similar, drained the entire fuel tank into the crankcase, I had it run about 10 seconds before I noticed this, shut it donw, drained the oil out twice
Old Jul 12, 2006 | 10:34 PM
kcrazie929rr's Avatar
i have a 01 929rr my motor is making a loud rattle when i turn the throttle can my motor be blown i have 16,000+miles on it thanks
