Power Commander?
Old Jun 17, 2006 | 11:45 PM
weeble1's Avatar
Default Power Commander?
I just put a 2 bros slip on on my 929 and it pops a lil when I lef off the gas, seems to be slight back firing. From what I know a slip on can make a bike run lean. Do I need to get a power commander and re map the system? Or is there another.... cheaper way to fix this problem? Thanks, Josh
Old Jun 18, 2006 | 06:54 PM
Y2K929RR's Avatar
Default RE: Power Commander?
Getting a Powercommander is pretty standard with a new exhaust. There is no cheaper fix. If you cant get a PC yet, you might be better off going back to the stock can until you do.
Old Jun 18, 2006 | 07:01 PM
bobjoezx's Avatar
get a PCIII and get it tuned!
Old Jun 18, 2006 | 10:10 PM
weeble1's Avatar
you say I might be better of with the stock pipe... is that because of loss of power or can it actually hurt the bike?
Old Jun 19, 2006 | 12:28 AM
Y2K929RR's Avatar
Itd not going to run right. Most likely too lean and that can hurt the bike.
Old Jun 19, 2006 | 01:03 AM
weeble1's Avatar
Well then back on goes the stock pipe. Thanks a lot guys! By the way, It's for sale! check it out in the for sale ads!
Old Jun 19, 2006 | 01:04 AM
matt365's Avatar
It's not backfiring. That is the PAIR valve injecting air into the exhaust to burn off unburnt fuel when you roll off the throttle.
You don't need a powercommander with a slip-on, and the sound is completely normal. Don't worry about it.
[IMG]local://upfiles/5496/682F5C5580EC4E159C1EC664A99F2CA7.jpg[/IMG]
[IMG]local://upfiles/5496/2DAFEBA73BB347E9AB42C9CAEDEA0F95.jpg[/IMG]
Old Jun 19, 2006 | 01:18 AM
weeble1's Avatar
well that's good to know because I didn't want to pull off the pipe, it sounds way too nice, haha. Thanks so much!
Old Jun 19, 2006 | 01:19 AM
matt365's Avatar
no problem man;
& definitely better than spending $300.00 on a PC3 when you don't need it
Old Jun 19, 2006 | 01:25 AM
weeble1's Avatar
haha, hell yea!
