please help!
Old Sep 3, 2007 | 08:35 PM
bubblehead1428's Avatar
Default please help!
hey guys,
i got a 00 929rr which is my daily rider. my front lights, low beam, high beam, blinkers and back light for the instrument panel are stuck off. the back tail light low side, and back blinkers are all on. i checked all the fuses under the seat. any help?!?!?!?!?!?!?!?!?! thanks a lot guys. any thoughts are greatly appreciated!
Old Sep 4, 2007 | 04:47 PM
sc929's Avatar
Default RE: please help!
Check and make sure the fuse is powered up. The fuse may be good but not have anyhting on it. If it doesn't work backwards, if it does work forward. Check each changeover pt for power. ie. connectors, switches, relays. I don't have a wiring diagram but if everything is out in the front it'll be a commonality. Might be a fusible link or ground too. Pull a headlight connector off and check there for continuity to ground with an ohm-meter. You may know this but should have zero ohms, if it is open then thats the problem. Hope that helps.
Old Sep 4, 2007 | 04:57 PM
mikey1297's Avatar
sounds like a ground problem tie into a ground off your turn signals and ground strait to the batery ground and see i that fix's it
Old Sep 4, 2007 | 07:30 PM
i tapped into the one blinker and directly grounded it to the battery and that fixed the one blinker. this leads me to believe that its a ground comming off of a harness somewhere, i just dont know where that would be.
Old Sep 9, 2007 | 11:01 PM
RCR's Avatar
RCR
Did you wash it and this happend? or just out of the blue it happend. Is this the only problem bike start, horn work, kill switch ect...
