Which PC map
I'm about to install my power commander and don't know which map I should use.
I have a scorpion highmount half system, my htev is locked in the straight through position and I removed the flapper from my airbox.
So I'm wondering if I should use the half system map or a full exhaust map. I figure since the htev is locked I should go with the full system. The half sysyem map I assume will still be tuned to take into account the different positions of the htev valve.
Anyone who has a similar setup to mine (Flapper mod, Htev locked half system) which map did you go with? Full exhaust or half sysyem?
Thanks
Thanks
Got the PC hooked up and working properly. Only thing I can't find a good map for my set up. I've tried almost all the full system maps, a few bolt -on maps and all the high-mount maps. The full system maps seem to work the best but every map I tried has a hesitation/stumble right off of idle (1400-1800 rpms). So to avoid the hesitation I have to give it a lot of gas and slip the clutch pretty long. Its pretty annoying especially in stop and go traffic.... and it sounds like I'm launching for a drag race at every red light.
A custom tune isn't feasible right now. So has anyone adjusted the PC manually (face plate buttons) with one of the tunes already loaded onto the PC? I figure I can play with the low RPM rang setting until I get rid of the hesitation.
Or
Can anyone send me their map thats tuned for the HTEV valve locked straight through? Or send me a screen shot of your fuel table?
Or
have you tried the zero map at all. try that one real quick compared to the downloaded maps of the PC site and that will give you a good idea which way you need to go fueling wise if you have to adjust it manually. give me your email and i'll send you my map. it might work a little better maybe ?
