929 wont start....
Old Aug 16, 2009 | 06:32 PM
hon00cbr929's Avatar
Default 929 wont start....
Okay I can't get my 929 to start. I noticed that I have the oil light on and the MIL light is solid, does anyone have any ideas what it could be wrong with the bike...
Old Aug 17, 2009 | 02:20 PM
letsride's Avatar
Did you check the oil level?
Old Aug 18, 2009 | 12:01 PM
HAVOC's Avatar
is it in gear? do you have the kill switch in the right position? does the bike attempt to crank over at all or do you just get a loud solid click and thats it? we need wayy more info to be able to help ya out.
Old Aug 19, 2009 | 08:13 PM
Oil level is good, the kill switch is in the right position and when I do try and start it I do hear a loud clicking noise....at times its does sound like it wants to crank over and then it doesn't but shorty after that is when the clicking starts up.
Old Aug 19, 2009 | 09:20 PM
HAVOC's Avatar
well that loud clicking sound is uaualy from a dead battery.. have you tried jumping the bike yet ?
Old Aug 22, 2009 | 02:41 PM
Yah I have and its a brand new battery......
Old Aug 23, 2009 | 12:56 AM
HAVOC's Avatar
just curious if you charged your new battery before hooking it up ? because if you just added in the acid and tried to hook it up chances are it isnt going to start.. (essentially a dead battery ) and when you tried to jump start the bike how did you go about it ? did you use a vehicle was thier motor on or not ?
Old Aug 23, 2009 | 05:11 PM
Okay I charged the battery. Now it starts for about 5 seconds and then dies. But when its starts its a weak start. When I gave it alittle more gas its dies on me.
Old Aug 23, 2009 | 06:47 PM
Well now its starts when I pull the throttle all the way and when I release the throttle its stops......
Old Aug 24, 2009 | 11:48 AM
HAVOC's Avatar
have you tried adjusting your idle control screw located near your stator cover ? if that has been messed with and the idle is too low that could be the problem. can you give a lil bit more history on the bike , has anything happened to it recently like a crash or new parts installed.. was it working fine before you couldnt get it started or has there been on going issues.
