Need Help on Bearing Colours please!!!
okay lets double check.first time i did numbers from right end to left wich was 3232 numbers.then after u told me i should done it oposite,so now the numbers will start with 2323 from far left to right.i also have one question,i saw how the plastigage should be done and everything how it mesure,and u told me that its about oil clearance,whant does it mean(wich oil i should use in motor)?what these measure numbers are for?
If motor was positioned just like it sits in bike, you start at the left. That is cylinder #1, then read to the right. Oil clearance is amount of clearance you have between the bearing and crank journal. Too little clearance and you'll burn up the journal/spin bearing because there isn't enough oil present. Too much clearance and you'll run into oil pressure problems.
