I need some help, pics pleases!
As the title says, I need some help with some pics of certain things. I am trying to put back together my 929 that was stolen and stripped of all its easy to sell fast parts. So I'm about two things away from getting it running now. I need to install a clutch cable but i think im missing the part that the cable connects to on the clutch side of the motor.
So if someone could post a pic or a few of how the clutch cable runs from the clutch cover to the lever would be great.
The second is that I need some pics of how the tank connects. From hoses to the wiring harness. The more pics the better for me.
I probally will be asking for a lot of help so thanks in advance.
got you covered. i happen to have 2 929's, one is dismantled. ill see about getting you pics. but, the tank hoses are simple.
big fuel line is pressure... side of the fuel rail, big banjo nut and washers.
small fuel hose...pressure regulator
bigger vent tube is a drain from the filler...open hose
small hose goes to the evap cannister.
ill work on those pics. let me know if you need anything else, glad to help!
Leveltwo
10-04-2008 06:55 PM
