Hindle header
Old Jan 27, 2012 | 08:25 PM
Hung's Avatar
Originally Posted by flyingpig70
Nice, I went with Carrillo rods but lightened the crank a lot...
That's good! how's the performance??
And Did you do something with your Crank ? machine aligment ? top RPM range?
I saw it, but I decided to go with titanium, why? because endurable, but Still I'm very interesting about this brand connecting rods..can you share some good performance?
Old Jan 29, 2012 | 10:22 AM
medicbaldwin's Avatar
how does the micron terminate, ie. 4-2-1, 4-1? I'm looking for a good flowing header for drag racing.
Old Jan 29, 2012 | 10:25 AM
Hung- you're going to custom make these headers? What materials are you going to be using and what are you going to sell them for?
In the mean time, can you custom make a 4-2-1 collector with a HTEV flange that'll bolt directly to the factory header? If so, what kinda cost would I be looking at for that?
Old Jan 29, 2012 | 06:52 PM
CTcbr929's Avatar
July 2012 Ride of the Month
Originally Posted by zaqwert6
They're micron serpent heads and they work. The concept is based on fluid dynamics. As exhaust leaves the head and hits the first bend, centrifugal force forces the gas to the outside of the pipe creating a vacuum and turbulence on the inside of the bend. By shaping the pipe in this way, it eliminates this phenomenon and allows the pulse to travel with less restriction and turbulence by forcing the gases to fill into the sides of the bend. Most pipes are designed on the theory of a garden hose which is incorrect as the pipe does not ever stay completely "filled" Its filled and exhausted in pulses which create different dynamics in the pipe.
They figured that out and quite well IMO.
Interesting Thanks for the info.
Old Feb 2, 2012 | 07:14 PM
zaqwert6's Avatar
Nov 2011 ROTM
4/2/1 on the sets I've had.
If your dragging I'd think you'd want 4/1 short runs, even sidewinders perhaps.
Old Feb 9, 2012 | 11:51 AM
Problem is no company makes a sidewinder for a 929. The companies that make them feel it's not worth their time to make a sidewinder for a bike smaller than 1000cc's.
I've seen a pic of a 954 with a sidewinder exhaust but it was custom made and had a 1000 motor swap
dustinjklee
Apr 13, 2010 02:19 PM
TripsD
Oct 17, 2007 09:44 PM
