help please
Old Jan 1, 2006 | 11:42 PM
ibkevman's Avatar
Default help please
I took the bike out for a spin the other day and the red light on the dash was lit up (idiot light) with the FI showing on the speedo window. then it went off. then it came back on. bike ran fine the whole time.
started it today and it stayed on. rode for 20 miles or so and on the whole time. manual basically say to take it to a Honda mechanic for diagnosis.
has anyone had any experiences with something like this? I'd like to take care of it myself without getting *** raped at the dealer.
thanks.
Old Jan 2, 2006 | 01:37 AM
GONECRAZY's Avatar
Default RE: help please
check your oil
Old Jan 2, 2006 | 01:41 AM
ibkevman's Avatar
ok. I checked it not long ago and it was cool. I'll change it and see what happens. is that linked to the FI idiot light?
Old Jan 2, 2006 | 02:39 AM
GONECRAZY's Avatar
the red light will com on if your oil is low...you also have the cali model so it can be the o2 sensor to
Old Jan 3, 2006 | 02:53 AM
Dave929's Avatar
I'd check the air filter to if it hasn't been changed recently.... that'll mess up the air flow and set it off..
Old Jan 7, 2006 | 05:46 PM
ibkevman's Avatar
air filter cleaned and replaced. it has a KN. wasn't too dirty. oil and O2 sensor will be next
Old Jan 15, 2006 | 10:52 AM
ibkevman's Avatar
found out the idiot light blinks a code to point me in the direction of the problem.
9 blinks. IAT (air temperature) sensor loose or faulty. $14.93 to replace. we'll see what happens.
Old Jan 26, 2006 | 07:37 PM
ibkevman's Avatar
well.....the saga has ended. I checked the connection to the IAT and the plug was pretty fouled up. cleaned it out real good and put it back together. Turned key............no dice. Still blinking 9 times. Called the local Honda service shop and they clued me in on erasing the codes in the computer. Read in the manual that you have to use a jumper wire to short out the service plug. Voila! After a few failed attempts, we are good to go.
