Fuel Pressure Regulator Bad When Not Leaking?
Old Jun 18, 2019 | 09:07 AM
jkjel15's Avatar
Default Fuel Pressure Regulator Bad When Not Leaking?
I have an '01 929 that starts and idles fine and runs great on top but is dropping a couple cylinders in the mid range. Once I hit a high enough rpm all cylinders come back on and it then runs great again. I have checked the fuel pressure regulator but there is no fuel leaking out the vacuum line, is it possible its bad even though it is not leaking?
Old Jun 18, 2019 | 12:08 PM
74demon's Avatar
Doesn't sound like a fpr issue to me. Do you know which cylinders a cutting out, or if they really are? What rpm does it start and clear up?
Old Jun 18, 2019 | 12:21 PM
jkjel15's Avatar
I do not know which cylinders or exact rpm as I don't have a gauge but its from about 1/4 throttle to 3/4 throttle. It just falls flat and definitely is not running on all cylinders but once you get past 3/4 throttle it picks back up and will sing to the rev limiter. What else could it be other than FPR? I have checked plugs, coils, injectors, throttle bodies, throttle position sensor, HTEV exhaust valve, stator, reg/rec.
mjdaily88
Aug 10, 2018 01:04 PM
Bryantsito
Mar 25, 2012 02:40 PM
Survivalism
Jun 24, 2011 09:17 AM
chromblue
Jun 16, 2009 11:20 AM
