fuel line kink
are you talking about the return line or pressure line? the pressure line, the one with the banjo fittings, doesn't usually kink. do not cut into this hose. the return line kinks a bit. i replaced mine with a little longer hose to help with the kink and it sure makes it easier to disconnect and lift the tank. its just regular fuel hose that is available at any auto supply. there is no need for a filter in the return line. your bike has a fuel filter inside the tank mounted with the fuel pump.
