front forks / accident
Old Jul 16, 2005 | 02:21 AM
gblader's Avatar
Default front forks / accident
Hello. I downed my bike not that long ago. the alternator is busted open, and the lower engine case is cracked. Should I just replace the engine as a whole? Will it be really hard to take apart the swingarm, engine, etc, to change the lower engine case? Any special tools? I'm am ok with the wrench - I have a mustang that I tweak all the time. Also, I can't seem to get the front forks off. There seems to be a tool that I need to remove th forks. Any help is greatly appreciated!!!
Old Jul 16, 2005 | 02:36 AM
abadfish's Avatar
Default RE: front forks / accident
Removing the forks doesn't require any special tools.
- put the bike on a rear stand
- put the front on a stem stand (or suspend it from, say, the rafters of your garage)
- remove the front brake calipers
- remove the front wheel
- remove the front fender
. loosen the pinch bolts on the triple trees
- loosen the pinch bolts for the clipons.
the forks should slide right out.
Old Jul 16, 2005 | 02:46 AM
gblader's Avatar
My bad - I have to remove the steering stem too - it cracked in half . . .
Old Jul 16, 2005 | 04:00 AM
abadfish's Avatar
Isn't the steering stem part of the frame?? If so.......you're f*cked!!! Insurance companies would total a bike that had frame damage.
Old Jul 16, 2005 | 04:46 PM
gblader's Avatar
no - not part of the frame. It's the black plate that holds the top of the forks together on the top. I got a new one that came with the forks that I bought. I just need to change them, that's all.
Old Jul 16, 2005 | 04:50 PM
abadfish's Avatar
ORIGINAL: gblader
That's called a triple tree
Old Jun 3, 2010 | 01:51 PM
Roast's Avatar
lol
TMAX
CBR1000F Wanted / Swap
Nov 18, 2009 12:41 PM
ImportCustomx
Nov 28, 2006 04:50 PM
abreu3r
Apr 24, 2006 05:55 PM
