front brake lever + brake light
does the front brake lever actuate the brake light on this bike? only reason im asking is because after i installed Hightech speeds' UFO led brake light kit the front brake lever does not light the brake light. only the rear brake. the kit had a harness so i couldn't have done anything wrong.
RE: front brake lever + brake light
I have that same kit. my brake lights work fine but my turn signals dont work right. i think it because i dont have any front turn signals. did you cut off the stock bulb housing or did you splice into the stock wires?
check your front brake line because if the rear brakes lever activate the brakes then it should be hooked up right.
My buddy and i have erion 929's and neither of our rear brakes light up the brake light. I do not understand???
ORIGINAL: Lord Jersey
No matter which one is pressed, you should have the brakelight come on. Something must have been messed up during the install.
LJ
LJ
Got a 2001 929 - both brake pedal and lever activate brake light. You haven't mentioned whether or not you are sure the hand lever was activating the brake light before the kit install. There is an adjustable switch on foot lever - don't think the switch on the hand lever is adjustable, but you can listen for it's audible click when you squeeze the lever. Also it's easy to hook up an ohmmeter to check it..
