forks spring rate?
Old 10-03-2007 | 09:58 PM
Ace_f4i's Avatar
Default forks spring rate?
anybody know the spring rate on stock 929 forks? i'm swapping the forks on my F4i for a pair of these. any other advice would be appreciated too.
Old 10-04-2007 | 12:47 AM
ApexClipper's Avatar
Default RE: forks spring rate?
The published figure I've seen is 0.7 kg/mm with other commentary that it's a progressive spring so about 1 kg/mm at full compression.
Here's a post about 929 forks, I can't vouch for his technical expertise but interesting reading nonetheless
http://cbrworld.net/forums/thread/227621.aspx
Old 10-04-2007 | 12:56 AM
Ace_f4i's Avatar
appreciate it bro. thanks.
Old 10-04-2007 | 01:18 AM
Roger that, good luck.
Old 10-06-2007 | 10:45 AM
Balamien's Avatar
http://www.racetech.com/evalving/menu/searchstreet.asp
Enter your bike in and find the custom spring/shock calculator. You can see the differance between a street/race recommendation spring sets based on your weight. Definately helped me on what I am going to get.
hosspowerinc
03-15-2015 04:49 PM
mazdarati
04-18-2008 04:38 PM
xtremef4i
02-10-2008 07:50 PM
IamEli
07-03-2007 05:12 PM
Bloodhound
07-01-2007 06:47 PM
