Fork Spring Rate
Old Mar 13, 2015 | 08:42 PM
hosspowerinc's Avatar
Registered Users
Default Fork Spring Rate
Does anyone know the front fork spring rate? Racetech doesnt show it nor does the service manual. I'm thinking of going with a 1.0 or 1.1kg spring to help with the excessive brake dive.
Old Mar 13, 2015 | 09:19 PM
74demon's Avatar
What's in it now is irrelevant. Since its diving, it too light and worn out. Get the spring rate appropriate for your weight. Racetech's website has a chart to pick the correct set.
How much do you weigh?
Old Mar 14, 2015 | 09:06 PM
Registered Users
Im 180lbs. Im aware of choosing the correct spring rate ( Ive built several track bikes) but Im curious how much of a rate increase Im looking at. I may go a little softer than "ideal" depending on whats in there now.
Old Mar 15, 2015 | 03:49 PM
74demon's Avatar
What's in there now was probably set up fora 140lb rider. They come pretty soft from the factory, then became even softer over the years.
Choose a little stiffer than what your target rate is. It will soften up a bit when it gets a few miles on them.
rk97
Jun 26, 2008 04:56 PM
mazdarati
Apr 18, 2008 03:38 PM
xtremef4i
Feb 10, 2008 06:50 PM
Ace_f4i
Oct 6, 2007 09:45 AM
Bloodhound
Jul 1, 2007 05:47 PM
