forget it delete this post
Old Jul 29, 2007 | 08:24 PM
grim129's Avatar
Default forget it delete this post
ya for get it im takeing the bike to a tec no pont in asking no more
Old Jul 29, 2007 | 08:33 PM
bignibb's Avatar
Permanent ROTM Nominee
Default RE: my bike is runing WAYYY TO rich
you really should put all you info in the one post so I don't have to address the same subject in different post!
the thing is you don't make a 02 sensor you have to buy one, the good news is it isn't redicously expensive.
and yes that is probally the reason your running rich and fouling the plugs.
Old Jul 29, 2007 | 10:31 PM
grim129's Avatar
no no i cant run a 02 on my set upp !!!!! man my powercommander PCIII says not to use itt!!!!
so i neeed to make or get a Oxygen Sensor Eliminator!!
Old Jul 30, 2007 | 09:14 AM
bignibb's Avatar
ok man your getting on my nerves now but I'm still going to answer you questions!
the deal with the 02 sensor is for emission purposes now when you start putting performance products on your bike, emisions go out the window!
now the powercommander won't work with a 02 sensor because if you add more fuel the bike will drop the amount of air to copensate and vise vesra if you add more air it will drop the amount of fuel to keep the A/F mix ideal.
now in order to get the full affect out of your powercommander and exhaust and airfilter, you need to do away with the sensor via a 02 eliminator
now once you get the 02 eliminator for the bike, I believe you can use any map not just a CA map for no 02 sensor!
Old Jul 30, 2007 | 07:37 PM
grim129's Avatar
i seee hmm yaa soo the way it isss NO O2 is y it runs like ****tttttt
richterat83
Mar 13, 2007 03:56 PM
pitsvtec
Feb 17, 2006 01:24 PM
arkas
Jan 26, 2006 08:51 PM
