Fan not Working???? HELP
Old May 10, 2007 | 12:56 AM
Bklynjoker's Avatar
Default Fan not Working???? HELP
Can anyone tell me where the Relay is for the Fan is located, Is there even a Relay for the fan??? my Temp went passed 250 blinking had to shutdown... fan didnt kick on.. what would be my 1st steps????? PLZ HELP ME..... is it a good idea to wirethe fanto be on all the time??
Old May 10, 2007 | 03:54 AM
jeh2324's Avatar
Default RE: Fan not Working???? HELP
I would....
Check coolant
See if the fan came unplugged
Test fan
Then possibly replace fan, I had one go out.
Old May 12, 2007 | 01:19 AM
romero20's Avatar
check the fuse
Old May 13, 2007 | 12:00 PM
blown hemi's Avatar
First of all you shouldnt let it get that hot ride it around tell you get it to cool down, Second of all check the Fuse under the Main Seat, if that looks okay, thenmake sure all wires are fully connected,You can alsomake sure the Fan blade is not hitting the radiator or any other part's,Ifyou know how to test the fan make sure thatitis getting voltage..If all checks good then you probably have a bad fan...I would then take it to a dealer. to look and run diagnostics on it...
HondaJunkie99
Jun 20, 2011 06:13 PM
snowboarding82
Feb 28, 2010 05:17 PM
Miller
Jan 17, 2010 06:06 PM
DakotaCBR
May 1, 2008 05:59 PM
willklee
Mar 30, 2008 05:57 PM
